(Topic ID: 266391)
Help with 6803 score displays
By Armyaviation
#1 4 years ago
I am working on A hardbody And the displays were working but flickering so I decided to reflow solder on the pins for the connector. I reheated the solder bit on some I added solder. I checked continuity between pins and none were touching but when I powered the on the power arced across the pins. I removed the excess solder a tried again, now no displays but power at test points is good. Any advice
#2 4 years ago
Check the fuse at the power supply board.
#3 4 years ago
I replaced the pins at the display board and now the one is working but intermittently.
#4 4 years ago
Btw the one display is working great. The other one is intermittent
#5 4 years ago
Did you replace the capacitor on the power supply?
Check the connectors for bad contact.
Sometimes battery acid has dripped down to the bottom of the cpu board.
Sometimes even the display connector....
This page was printed from https://pinside.com/pinball/forum/topic/help-with-6803-score-displays and we tried optimising it for printing. Some page elements may have been deliberately hidden.
