Quoted from ksnuclear:Hi Everyone.
I recently acquired a 66 Wms Full House. It is coming along nicely but I can't figure out how the 1 pt. bell is supposed to work. It is on the bottom of the match step unit but I don't see anything to stike the bell. Attached is a pic of the unit. Any input or pics of how it should be set up would be helpful.
Thanks in advance for your help.
John P.
00-90 Unit.jpg 472 KB
The loose looking thing on the left is the clapper. From this picture, it looks to me like the bell is adjusted too far away from the clapper. Loosen the screw on top and move it all the way over toward the clapper.
I've seen instances where the coil sleeve on these is metal and the plunger won't pull in far enough to move the lever far enough for the clapper to hit the bell. You might want to replace that too.
As far as I can see, your unit is complete but just out of adjustment.
Here's a picture of the unit on Top Hand, which is the AAB version of this game.
http://www.ipdb.org/showpic.pl?id=2581&picno=31607&zoom=1
