Hi all, I need a little nudge in the right direction please...
I want to put a mod in a system 11, basically where I press a switch and a coil fires
I found a relay that needs (3vDC to 30vDC). to use as the switch and can activate up to 240vDC
CG Solid State Relay SSR-25DD DC to DC Input 3-32VDC To Output 5-240VDC 25A Single Phase Plastic Cover https://www.amazon.com/dp/B08GNSPCND/ref=cm_sw_r_cp_api_i_32ZNKK4BVXX2WNB0MF6A
So... I don’t want to send voltage through the gnd if it’s going to hurt something unintended, but I’m sure I’ll need to use common gnd anyway... here’s my diagram I drew, anyone know what I need to do to accomplish my goal and not blow fuses or release the magic smoke?
Help is greatly appreciated , thank you
