(Topic ID: 263875)
Help understanding this switch matrix
By Bax1
  • 21 posts
  • 4 Pinsiders participating
  • Latest reply 3 years ago by Bax1
#1 3 years ago
Working on a gottlieb Monte Carlo. The switches ending in 0,1, and 3 all show closed in test mode. 65 does as well. When you start a game 65 is the trough coil and constantly fires. What ties these vertical rows together? Want to understand this better and appreciate the help.
#3 3 years ago
Thank you for replying Chris. So I found two ic chips were bad z11 & z13. So all switches are working now except 65 which confuses me which diode it is. Schematic says 14 but there are only 13 on there. I also found the one on the end of the board was blown. Wondering if I blew the chip again due to diode being bad
#4 3 years ago
Quoted from Bax1:
Nope. The worst that could happen would be a "ghost" switch would be reported, and that requires the diode to fail shorted.
For switch 65, my money is on a failed switch or a wire/diode touching where it should not be. Since the game is reporting it as closed, the diode is not the issue. The switch must actually be closed, via the contacts or other. Let's see a pic of it.
Chris Hibler - CARGPB #31
http://www.ChrisHiblerPinball.com/Contact
#5 3 years ago
Here is the pic of the switch. Contacts are open. Even if you pull it away more, it still registers.
34A7422D-D042-46ED-A859-C70C76A800B7 (resized).jpegFF47E00B-0B54-4058-91B5-02E41FE073BD (resized).jpeg
#6 3 years ago
Look at the lower switch blade. It has a shorter zinc plated retention blade just above it - they sit in the bakelite stack together so are connected.
Your retention blade is bent right up touching the upper switch blade = shorted switch..
See how the retention blade should be with its tip against the lower switch blade:
#7 3 years ago
Quench good eye!
-Mike
#8 3 years ago
Dang someone has an eagle eye!! Thank you. I may have this thing fully working now! This is why I love pinside!
#9 3 years ago
Quoted from Quench:
Your tensioner blade is bent right up touching the upper switch blade = shorted switch..
Quench , Bingo.
Bax1 , Thanks for the pic. It was worth 1000 words.
Both of you, may I use these pics in the PinWiki?
#10 3 years ago
Quoted from ChrisHibler:
@quench , Bingo.
@bax1 , Thanks for the pic. It was worth 1000 words.
ChrisHibler, no problem with me! if you want the PNG version before I compressed to JPG, PM me although I didn't compress it much. I probably need to PM you at some point anyway about adding other content to PinWiki.
#11 3 years ago
Quoted from Quench:
Sure...I can see from your posts that you know what you are doing. I like reading your posts.
We can establish a PinWiki account for you. Editing and adding content is relatively easy.
Or, I'm happy to help. I'm retired from my day job now...so it's all pin all the time.
I added the image to the wiki...betting that Bax1 will be OK with it. Scroll down a bit. I want to do more work on this section. I wrote it a long time ago and I could never get my PowerPoint animation to work quite right.
https://www.pinwiki.com//wiki/index.php?title=General#The_Switch_Matrix
#12 3 years ago
I’m good with using them. Anything to help others!
#13 3 years ago
Btw. Game plays now. Need to adjust a switch probably due to not registering but super happy I can finally play it!
#14 3 years ago
ok so have some more issues I am finding. I have a flasher and the coil for the left ramp are not working. So Lamp13 is the ramp and lamp 14 is the flasher. I just replaced the coil due to it being fried. must have been fried since I have had this. but anyways. pulled the driver board and tested Q14, Q15 transistors, also tested out Z4 ic. all test out good. what could I be missing? Really appreciate you guys helping.
ChrisHibler Quench
#15 3 years ago
Downstream from transistors Q14 and Q15 are power transistors Q5 and Q1 respectively which drive lamp 13 (ramp solenoid) and lamp 14 (left domes). You need to test those two transistors.
#16 3 years ago
Not q1 & q5 test good. Could these be tied to one of these little boards underneath the playfield?
#17 3 years ago
Quoted from Bax1:
Both q1 & q5 test good. Could these be tied to one of these little boards underneath the playfield?
#18 3 years ago
Quoted from Bax1:
Quoted from Bax1:
How did you test the transistors and particularly Z4?
The lower left dome flasher lamp next to the left slingshot is on the same circuit as the upper left dome flasher lamp. Are both those left dome lamps not working?
It looks to me like the ramp coil has some sort of End Of Stroke (EOS) switch associated with it that's activated by movement of the ramp. Is that switch operating properly when the ramp is down and up? I guess the switch should be normally closed so the coil has higher power to lift the ramp.
What happens when you very briefly ground the base leg of transistors Q5 and Q1? Do their respective lamp/solenoids flash/activate?
#19 3 years ago
for the Z4 I was in diode test. put the pos lead on the ground and made sure I was getting reading on the other legs. verified vs other like ic's. the flasher next to the slingshots do work. this is the only flasher that does not. the switch for the ramp is open when up and closed when down. so the coil should be activated most of the game play. you have to hit some shots to get it to lower which would close the switch. have not grounded the transistors. not sure which leg to ground and how I could with them being so low on the board. not able to get it at the back when connectors are on.
#20 3 years ago
well
I am officially in the dummy club. I didn't check the fuse and what do you know, it works. the ramp works but the flasher doesn't yet. probably going to look at the socket itself. I have a feeling that is the problem. previous owner had wrong fuses in too. had a 1amp in a 2.5amp spot which obviously fried it and probably the coil too.
#21 3 years ago
thank you with the help Quench
Other
$ 5.95
The Pinball Scientist
Protection
$ 83.00
PinballReplacementParts
Men
Gweem's Mods
Sound/Speakers
1,500
Marshville, NC
This page was printed from https://pinside.com/pinball/forum/topic/help-understanding-this-switch-matrix- and we tried optimising it for printing. Some page elements may have been deliberately hidden.
