Recently my TZ developed a problem. I have only noticed it so far in multiball. I first noticed that when a ball would drain that it would just sit in the trough and the outhole kicker wouldn't kick it over into the trough. I though it might be the outhole switch, but it tested fine in test mode and I even bent the arm up slightly. I then noticed when it won't end the ball and a ball is sitting in the outhole that the coil that kicks the ball up into the shooter lane keeps firing even though there is no ball there.
Here's what I've checked so far and everything has checked out fine:
1.) two ball lock optos
2.) one ball lock switch
3.) all trough switches, including far left switch
4.) outhole switch
5.) outhole kicker
6.) confirmed the game has 6 balls- five steel, one ceramic
Can anyone tell me what to look at next, I'm at a loss.
