(Topic ID: 320389)
Help! Toy Story 4 will not boot up. Motherboard SATA cable?
By MurphyPeoples
7 months ago
#1 7 months ago
My TS4 had no sound coming from the left speaker from day 1. On 8/9/22, it would not boot up at all, and had an "F1 Default" message on the LED.
This morning I cut it on to check again, and got no power at all. Everything dark like it had no power at all. Checked power to the Pin and it was good. (I keep all my pins on a line conditioner/power surge protector).
This morning I saw a reply from JJP regarding the pin not booting up. It said:
"With the game off, reseat both ends of the SATA cable (at the motherboard end, move it to a different port - at the hard drive end, unplug and replug the SATA cable)."
I checked the TS4 Manual and searched for "Motherboard" to figure out which PCB card was the motherboard. It does not have that info. Could someone let me know which is the motherboard, and what it means about moving the SATA connections? Thank you!
Murphy
#2 7 months ago
I checked the fuse, and it was good. I also checked the switch box outlet for power - it was good too. See pic.
Yet game acts like it is getting no power at all.
#3 7 months ago
Here's the message I was getting when it wouldn't boot all the way up, and just before I had no power at all.
#4 7 months ago
You might need to jump it with a screwdriver or a paper clip , I had to do this on my wonka. Or try plugging in a key board first and press F1 to see what it does.
#5 7 months ago
Quoted from Blackzarak:
There should seriously be no need for anyone with such a new machine to have to do anything of the sort!!
-1
#6 7 months ago
Quoted from guard:
I agree - this is EXACTLY what happens when you 'cheap out' and use a standard, $100 PC motherboard to run your $10K game rather than developing the CORRECT electronics for this commercial application as Stern does and as Bally and Williams did.
For those who disagree with me, please ponder these questions:
(1) How long does it take for your PC motherboard pinball machine to boot? More than 15 seconds I will bet!
(2) What happens when your PC motherboard in your $10K pinball machine is 10 years old and dies (that's just what they do)? You have an expensive paperweight because that original PC motherboard will be LONG obsolete rendering your game worthless!
(3) Why are so many having BIOS screens appear when they just want to play pinball? (answer - because that's just what PCs do, they are NOT reliable nor designed for commercial applications).
#7 7 months ago
There’s a lot of coin op equipment that runs on standard PC hardware. Hell my Big Buck Hunter has a full on Dell PC inside, case and all.
-1
#8 7 months ago
Quoted from KevInBuffalo:
How many PCs are in your home that are older than 10 years? Not many people have them this long because they either die or are obsolete.
EXACTLY the same situation applies when you use this type of 'throwaway' electronics in a machine you hope will last many decades, it just won't.
Your BBH was never designed to last more than 10 years - it is a throwaway arcade machine like most of the video arcade machines.
#9 7 months ago
Quoted from pins4u:
In addition to the PC in my Big Buck Safari (released in 2007, making it 15 years old) that is still functioning properly, I have a PC from the mid 90s in my house that I use for video game hobby stuff. I also have a Radio Shack TRS-80 Model 3 from 1980 in a box in my closet upstairs that I'm sure would work if I dug it out and plugged it in.
#10 7 months ago
Quoted from MurphyPeoples:
Look on page 78, item 16.
$ 649.95
Pin Stadium Pinball Mods
Interactive
Other
Precision Pinball prod.
Flipper parts
$ 15,000.00
Classic Game Rooms
10,250 (OBO)
Coopersburg, PA
$ 350.00
Eville Pinball
Armor and blades
Filament Printing
Other
This page was printed from https://pinside.com/pinball/forum/topic/help-toy-story-4-will-not-boot-up-motherboard-sata-cable and we tried optimising it for printing. Some page elements may have been deliberately hidden.
