Looks like a SOT-23 Transistor.
My guess is something like this: http://www.s-manuals.com/pdf/datasheet/2/s/2sc1623_galaxy.pdf
Quoted from Adams:Looks like a SOT-23 Transistor.
What would be a way to verify? Or check to see if it is the same?
Quoted from Wisker:What would be a way to verify? Or check to see if it is the same?
Do you have the manual for the pin? Hopefully the manual includes a schematic which will specify exactly what part that is.
It might also give an answer on the missing component on the right side of this pic, just above where the solder mask says "LED", next to that JST connector. Looks like a spot for 2 resistors but only 1 is populated. not sure if the other was also knocked off or if it was never populated in the first place.
Quoted from Adams:Do you have the manual for the pin? Hopefully the manual includes a schematic which will specify exactly what part that is.
No manual its in a arcade, 600$ for a new board worked fine till i knocked off the l6 little chip moving the cabinet. L 6 isnt allot to go on, no manual its a 12k machine from china.
Nope just this one, i watched it as it fell off, just tapped corner of the board
OK -- Guessing here...
Series resistor with slew rate capacitor to pin 1 and not a heavy trace so this is the control line.
Heavy traces to pins 2 and 3 -- power traces.
Based on the connections to the inductor, two other transistors and the capacitors -- I'm betting this is a small MOSFET transistor as a tap from an on-board switching power supply.
Possibly something like a Fairchild FDY300NZ? ... maybe.
Quoted from G-P-E:OK -- Guessing here...
What are my options for figuring it out? I tried testing the others but got readings from all three legs
Quoted from Wisker:What are my options for figuring it out? I tried testing the others but got readings from all three legs
Only definitive answer would be to email the original manufacturer.
Quoted from Travish:Did it break? Solder it back on? Zip ties and jumper wires for $600.
Yea it broke off where it connects to the chip no legs to solder to
Quoted from barakandl:my guess from the L6 marking on the others.
https://www.mouser.com/ds/2/258/2SC1623(SOT-23)-276330.pdf
Yes that was the right one, fot it insralled amd game is working
Thanks all for thew help, on to my next project
This page was printed from https://pinside.com/pinball/forum/topic/help-to-identify-component-on-a-pcb-micro and we tried optimising it for printing. Some page elements may have been deliberately hidden.
