I noticed some corrosion on my Indiana Jones just below the battery holder. Been meaning to swap it out to external, figured now is the time and I could clean up the board. Snipped off battery holder. Started to clean up resistors but the top two were pretty crunchy. They broke. Not a big deal, I removed them and swapped them out after cleaning board with distilled vinegar. Plug machine in and it goes a little nuts in test mode. Pulled board back off and replaced other two resistors. Tested leads on both sides of resistors to u16 chip. Everything measuring as it should. I noticed on one side of the resistors they all seem to be touching but I think that is okay. They all connect to the same lead. See picks and video. Game just continually cycles through the test mode as if every switchs are firing.
Video:
