When the spinner switch is activated, the game moves to the next ball, and all drop targets reset as if the ball has drained.
All other switches seem to work as they should. In switch test, everything seems to function properly. Although, I am not able to activate the spinner switch in test to see if it is activating any other switches since it only shows the lowest number switch.
I am guessing that when the spinner switch is activated it is also triggering "L. Outhole SW." since they are on the same row. But I'm not sure why. All diodes have tested good on that row.
What should I check next?
