Hey guys - just picked up my first Data East game; a Maverick with a few issues I am trying to work through.
I have some experience with Early SS Bally/Sterns but I'm getting stuck here. Just looking for some input/guidance to get this one working.
Let me give you a rundown of this project so far and the problems I'm trying to figure out.
When originally picked up the main issues as told was, the DMD was dead, as well as the flippers.
- So far, the DMD has been replaced and is working 100% as far as I can tell.
-power supply has +5 and 12, but -12 isnt there. reading .500~
-low volume on speakers, and very loud hum/buzz from speakers(louder than the usual DE hum) volume pot inside coindoor does nothing. I’m guessing this is due to the missing -12V
- It came with a Rottendog flipper board and new coils, which are now for the post part working.
Originally they only seemed to work in the test menu, but they do work in game (somewhat). The ball lock coil isnt working so it has to be fired manually to eject the ball into the shooter lane. Once plunged the flippers have power. I assume this is working as intended?
I've gone through the test to track down some other coils/flashers that are not working and have highlighted the attached page from the manual.
I'm trying to get that ball lockout in the trough/shooter lane going first but suspect that a few of these issues are linked.
So far, the following has been done.
-confirmed power to the coil. reading 45v on both lugs
-confirmed the diode at coil is working, even replaced it with a new one, banded side to the power lug
-replaced q46 transistors
-shorted q46 to ground, coil fires
-confirmed continuity from connectors to coil on cpu/ppb
-reflowed all pins on both ppb and cpu
I am starting to suspect an issue farther up the line in the ICs but would like to exhaust my options prior to shotgunning ics as i currently dont have access to a logic probe.
Any help/input would be greatly appreciated! Maybe some of you DE guys see something I don't
