Machine resets fine. During first ball if any 100 point targets get hit it goes to game over. Further investigation actuating 100 point relay in back box same result. The machine will reset with the playfield removed with same result. All coils resistance appears in spec. All switches appear to be adjusted correctly. At times it will blow the 15 amp fuse. the actual contacts located on the 100 point relay appear to be a power supply to many of the playfield switches and can be traced to a number of the lower board relay contacts. Any thoughts?
Thanks in advance for any help. Should I have posted this in EM Hangout? Would I be in violation if I posted both?
[email protected]
