Just picked up a stainless steel coin door (from a fellow Pinsider) to replace the black one on my Sorcerer. Very excited.
Question: what's the best way to line up the pins on the wiring connector? They are not matched up equally...
Both doors have the same pin connector (thank god), but I need to make sure each pin is in the right spot.
a) what's the best way to ensure this?
b) what tool should I use to remove pins and move them to a new spot?
I think I have the same amount of pins, and the same connector, so I'm hoping it's doable.
thanks!
-mof
