Does anyone here have experience fixing digit or segment issues on these early Williams displays? I've considered getting LED upgraded displays, but the cable would still have to work correctly even for those. If Wolfpac included cables I'd be all set.
Game 1 - Williams Flash
Symptoms - center digit out on all displays
I thought it would be easy to repin, but after I cut the first wire I realized my replacement pins were smaller than the original. I haven't been able to identify the right size, but I have seen this same connector in pictures of other Flash games. Does anyone know where I can buy the right pins? Picture shows original with blue wire after being cut, and new but too small replacement pin.
Game 2 - Williams Blackout
Symptoms - top segment out on player 1, 2, and credit, but problem goes away if I use the cable from player 3
These are AMP brand connectors and use IDC pins. I'm not a fan of IDC, but I'll repin using them if that's all I can find.
