Hi pinsiders,
I'm new here, and new to pinballs in general. My step family had a Data East - Back to the Future pinball sleeping in their garage for almost 20 years.
The pinball is from 1990, they forgot about it after it broke down. I'm trying to repair it.
I've had a specialist (in France where I am at the moment) who repaired the power supply and CPU boards. The CPU board had battery acid damages. So a lot of components are new on those. I had to fix a transistor on the PPB myself to get 50V to the flippers. The pinball worked for one day, but while I was testing some lamps, I think I got a shortcut. While I was levering the playfield, lights started twinkling, and I heard a clacking noise. I turned it off, but when I turned it back on, no more booting. Had a couple fuses blown out, on the power supply and PPB boards. I replaced them, the pinball still doesn't boot, with the 5V and PIA leds always lit.
What it does :
- 5V and PIA leds always lit on the CPU (no flashing of any of the leds)
- low 5V on the power supply board, only 2.3V. 12V ok (14V/-14V). If I disconnect CN6, I get the 5V back. Something is wrong when CN6 is connected (I got that it supplies the other boards?)
- The fuses are all fine, the capacitors look ok on the power supply (and have been replaced very recently), I get the right voltages at the fuses of the power supply, and 43v at CN3 (where it should be 34V, but I guess it's ok?)
Before a couple months ago, I knew nothing at all about pinball, and really not much about electronics. But I have the manual and the willingness to learn.
Any help would be much appreciated ! Thanks !
