(Topic ID: 308169)
Help removing side rails (Bally Grand Slam)
By Rascal_H
2 years ago
#1 2 years ago
Sorry if this is dumb. I’m used to working on newer games with obvious screws locking down side rails.
What’s the trick to removing these side rails without causing too much damage? Just seeing some small little holes underneath.
Game in question is 1983 Bally Grand Slam. Thanks!
75C6C8EB-E497-403A-A69A-D60850C5B337 (resized).jpeg75C6C8EB-E497-403A-A69A-D60850C5B337 (resized).jpegC8B2E5AA-3691-45E2-9ED9-4F64DD6C70C8 (resized).jpegC8B2E5AA-3691-45E2-9ED9-4F64DD6C70C8 (resized).jpeg
#2 2 years ago
The are held on with staples, you can get a small flathead screwdriver and pry them out gently. Once you get a small gap you cam either pull the rail off from the top or continue pulling the staples.
#3 2 years ago
I would pre-drill some new screw holes before you remove it so it will fit back into place when your done.
#4 2 years ago
I use plastic pry tools to remove the wood rails that are stapled in.
F0C563DE-F921-4FA4-967C-545D4E5E9CA3 (resized).jpegF0C563DE-F921-4FA4-967C-545D4E5E9CA3 (resized).jpeg
$ 18.00
$ 18.95
$ 9.95
$ 199.95
This page was printed from https://pinside.com/pinball/forum/topic/help-removing-side-rails-bally-grand-slam and we tried optimising it for printing. Some page elements may have been deliberately hidden.
