(Topic ID: 223286)
Help Reading Oscilloscope
By oldschoolbob
1 year ago
  • 3 posts
  • 2 Pinsiders participating
  • Latest reply 1 year ago by oldschoolbob
    #1 1 year ago
    Still learning to use my new toy. A while back I built a simple tester to check zero crossing on my MPU. It's just a 24 volt transformer with a bridge rectifier. When I hook it to my volt meter I get 24.36 VDC.
    When I connect it to my oscilloscope it shows 38 volts peak to peak. The scope is set to 10 volts per division - counting the divisions I show pretty close to 38 volts.
    When I check the 5 and 12 volt supply it shows 5 and 12 volts with a steady line across the scope. (The 5 and 12 volt supply is regulated)
    I'm sure the scope is reading correctly - I just don't understand what I'm seeing.
    I know the 24 volt unregulated should show the wave form like I'm seeing - But I thought the waves should peak at 24 volts.
    Can someone please explain what I'm looking at?
    Bob
    #2 1 year ago
    AC is measured as RMS (root mean squared), so the reading you get isn't the peak. Unfiltered DC is just inverted AC, so the same logic applies.
    #3 1 year ago
    Anyone that doesn’t think electronics is fascinating is missing something. I wish I’d studied it more when I was younger.
    After seeing your post I thought I’d try another experiment. I opened up my tester and checked at the transformer (before the rectifier). WOW. My little 24 volt transformer is outputting 80 volts – peak to peak.
    Then I read up on RMS. I understand (sort of) what RMS is but the calculations are a bit beyond me. Thank goodness for DMMs. It looks like it does the calculation for me.
    Then with some really rough calculations I figured the 110 volts in my house is really like over 300 volts – peak to peak. No wonder they say AC is more dangerous than DC.
    Thanks for the lessons on electricity.
    Bob
    $ 164.99
    PinballBulbs
    $ 199.99
    $ 4.49
    $ 9,500.00
    Nitro Pinball Shop
    $ 1,000.00
    Playfields
    Pinball Playfields
    $ 159.99
    $ 60.00
    $ 40.00
    Arcade Arts
    $ 36.99
    Lee's Parts
    $ 208.87
    $ 125.00
    Sparky Pinball
    $ 159.99
    $ 22.00
    $ 69.99
    PinballBulbs
    $ 48.00
    $ 29.95
    Hardware
    Filament Printing
    $ 48.00
    $ 76.95
    $ 22.00
