I will admit, I did have one issue now that I think about it. Years back I had a Williams Flipptronics I/II Board. I would put it in one williams machine and all coils would lock and blow fuses on the board. I take the board out and try it in a different Williams and it ran perfectly. I then took an original Williams board from the other machine and it ran perfectly in the machine that would blow the Rottendog. Tried the Rottendog in a few other Williams and all worked fine. For some reason, it would blow up in one machine but not others, even though all the machines I tested it in are compatible . So, that is one thing to consider. May it be a bad product or just not entirely compatible as intended, not sure. But, in "most" cases it should run fine. And I can confirm the DE Universal Flipper Board works in JP.
I do have a repaired DE JP Flipper Board that I fixed that I may be willing to sell. However, it has a History of previous owners repairs. AKA looks horrible, the board is riddled with previous repairs. So, not sure.. probably just keep it as a backup.
