I am doing a playfield swap on a Banzai Run and I broke a couple posts off screwing them into the new playfield. Can anyone recommend a good way to extract the broke post?
Don’t risk damaging the Playfield. Get one of these.
https://www.homedepot.com/p/RYOBI-Spiral-Screw-Extractor-Set-5-Piece-A96SE51/205469301
There are other styles too.
Ok, first I have to ask how hard are you torquing these things down to snap them? I see stress cracks in the clear around the ball guide screw too. Ease these in...
That screw looks way too small to try to center drill and use a a standard extractor on.
Now. What I would do. I’d buy a screw extractor from Rockler. It’s a pain in the arse to use but it drills *around* the broken screw. I use these when I can drill a new hole all the way through. I then use a post I can secure with a locknut underneath. Far more secure against angry pinballs.
*extractor disclaimer. Much easier to use if you make a guide block to drill through and clamp it down to the playfield-examples of this are online- and these things are brittle. If you screw up and hit the metal screw, it will break some teeth. If you don’t have a Rockler nearby, order two.
And note they have several sizes. Pick the one that works for you.
Quoted from jhanley:
Are you drilling a pilot hole before installing the stud?If not you need to.
Yes this was my mistake. I need to drill out each hole to make them a little bigger. The copper type post studs are very weak and it doesn't take much to break them. It didn't take much tork at all.
Quoted from MrArt2u:
Great suggestion, i just ordered one of these. It maybe the only way to go. They are not stress cracks you are seeing, just micro scratches in the clear.
Quoted from Gritty:
Ugh. Why does everyone keep suggesting these? They leave an ugly patch in your pf. Not what you want to see on a restored machine.
Here is the best solution. Not as cheap as the ugly bore & plug method. But a better method used by pros:
https://pinside.com/pinball/forum/topic/a-joust-restore-insert-catchy-title-here/page/2#post-4552766
Heck no on that huge hole saw! Use a small center punch or hardened nail head to put a start point in the center of that screw. Put painters tape around the area to protect from scratches. Slowly Drill a 1/16” hole down the center of that screw. Proceed to a 3/32” or 1/8 inch drill after. When clear, If the hole is a bit large put a drop of epoxy or filler in the hole and drill new hole to mount post and done.
I suggested it because I restore dozens of playfields a year and use these whenever I run across a broken stud topside, particularly if it was broken by ball contact. Using a locknut/washer under the playfield makes for a more secure post when the job is done. What type of ugly patch are you talking about? This method drills a hole through the playfield that you then fill with a new post and secure from below. I’m not talking about using it for under playfield screws, there’s a hundred other ways to skin that cat.
That said, I followed your link and am willing to try that method next time if I remember it. You can never have too many tools.
Quoted from djblouw:
I have had great success just putting some thick tape on the playfield for protection, then drilling a very small (1/16) hole in the center of the broke off screw, then use a hand turned drive (not powered) screw extractor that is just a tad bit bigger than your 1/16. It will grab and get the screw up above the playfield just enough to then either 1.dremel a slot in it to remove it with a small straight screwdriver OR, place tiny vice grips on it and turn it out the rest of the way. I've used this method many times without failure for 10+ years. It is time consuming but if successful, you can never tell anything was ever wrong with that screw/post.
Sorry, didn’t mean professional pinball restorers; Wooden boat restorers, and all the screws that break off from rust.
If it’s a high hit area, coring the screw out and adding a t-but would be okay. But this is just a simple plastic spacer post. Plus it looks awfully close to that lamp socket. I’d rather replace it with the same type post, I to the same hole.
