I’m having an odd issue with the Police Car motor on my Police Force. The car will run and the motor will only travel on direction. It hits the switch but will not reverse.
Here is what I’ve done so far:
1) checked police car up and police car down switches. Both work fine in test
2) reflowed the connections on the little aux board (made no difference)
3) bought a replacement aux board from Marco (made no difference)
You can move the car by hand and when you fire the game it the car moves to the end and keep running as if the switch isn’t working but it is.
Thoughts?
