(Topic ID: 206796)
Help please! Pinbits Creature Pop Bumper Upgrade Kit
By Pinrookie
  • 6 posts
  • 3 Pinsiders participating
  • Latest reply 3 years ago by Pinrookie
#1 3 years ago
Hi there
Does anyone installed this kit from Pinbits?
This is the link:
http://iobium.com/flashers_in_the_pop_bumpers.htm
In general, I am very confused in step 3
My question is where is this red wire connected to?
The picture show (pic 1) the large diode with a red wire is connected to the bottom right flasher. However, where is the other end connected to?
My guess is connected to the above flasher? I am not sure at all.
If anyone can answer my question that would be great.
Many thanks
#2 3 years ago
Non banded side of the diode is the red wire, other end on the red/white wire. The red wire is the common, and pointed it in step 2 pretty well.
#3 3 years ago
This kit has been sitting in my garage for years. One of these days, I’ll work up the guts to give it a go.
#4 3 years ago
Quoted from dsuperbee:
Hi dsuperbee
Thank you for the reply. Is it means banded side is connected to the bottoms flasher with red/white wire?
The reason why I ask this question is step two is not connected to the bottom flasher. Actually based on the step 2 pic the common point is connected to the flasher that is above the bottom right flasher without diode.
Should I just ignore the step 2 picture just connected the red wire from the common point to the bottom flasher (red/white) with a large diode?
Many thanks
#5 3 years ago
Quoted from 30FathomDave:
Lol! I will let you know once I successfully installed this kit. Currently the pictures from Pinbits are very confusing.
#6 3 years ago
Quoted from Pinrookie:
Finally I managed to install this kit successfully. I connected my red wire to the bottom right flasher (red/white wire) with a large diode. On the other hand, I didn't connect any red wire to the above flasher at all.
$ 279.95
Pin Stadium Pinball Mods
$ 229.99
