My newest pin was being delivered by a fellow Pinsider this morning, so I went around turning on all my machines so he could see them real quick before hitting the road. When I turned on JP, the testing started and everything looked fine, but the DMD just had a few pixels lit and they weren't moving. So I turned it off/on (see below) and it did the same thing, but this time smoke started billowing out from around the Rex, and before I could switch it off and unplug it, smoke was coming out from behind the translite. (Honestly, the smoke/fog around the Rex would look awesome under different circumstances.)
I took off the translite and flipped the light board out, and I saw nothing that was on fire, smoldering, or looked damaged. We got it right at 2 years ago, and at the time we installed a new DMD in it, so it's not that old nor has it been messing up otherwise.
Disclaimer: This particular JP occasionally will not boot up properly, and will either display "OPEN THE COIN DOOR" and once you do it revert itself back to factory settings, or it will just not do anything but have the dino scream noise. I've been told it's the "starter" having a problem warming up, and just to turn it on/off again, which actually does seem to fix the problem. I know nothing at all about boards, so I just turn it on off/on and it works, so I haven't looked into it further. I guess we'll have to now.
I had to get to work and didn't have time to look into it further (or even unwrap my new LAH) but wanted to ask if anyone had an opinion on where I should start looking. I'm quite afraid to plug it in at this point. I was wanting a project machine, then got the LAH which is supposed to be working 100%, so I guess JP decided to be a jealous pissy bitch and turn itself into a project. Sigh. Thanks in advance for any suggestions/help.
