When I was starting my basement I measured the current being pulled by each machine before I decided on how many circuits in the basement. TSPP was seeing an average just over 3A, but a start up around 6A. STTNG on the other hand was running over 4A, and around 8-9A startup.
These numbers are off the top of my head, but I believe they are withing a couple percent of what I measured. The average number are also with the machine just sitting. Current while playing seemed 10-20% higher. The killer is at startup, so I decided to not switch my circuits and turn each one on individually to avoid tripping the breaker.
I planned 4 machines per circuit and have not seen any issues. I also planned out the spacing of the outlets so that there was one between each pair of machines.
Good luck with your build.
JDH
