(Topic ID: 180891)
HELP NEEDED? Who can rescue all data from a 16GB USB stick?
By german-pinball
2 years ago
  • 29 posts
  • 11 Pinsiders participating
  • Latest reply 2 years ago by Crash
    #1 2 years ago
    I have a really great problem with a VERBATIM 16GB USB stick. Windows 7 detects the stick and I can see als folders, but when I double click a folders, the stick disconnects.
    I tried nearly everything (chkdsk, PC Inspector file recovery and more), but I have no access to my very important data.
    I really need professional help - please rescue the last 5 years of my life.
    Hope, that anybody can rescue me.
    Thanks in advance.
    Ingo
    #2 2 years ago
    I've used this free software before to recover files from a USB stick. Don't know if it'll help in your situation though...
    http://www.easeus.com/resource/drive/usb-flash-drive.htm
    #3 2 years ago
    Quoted from Snux:
    Thanks mate. I just bought the license for that software and will try.
    But I think, it is a hardware problem, I will try now to solder an USB-cable directly to the connector as shown here:
    http://www.wikihow.com/Repair-a-USB-Flash-Drive
    #4 2 years ago
    Although it probably won't help you now, never use a flash drive as your primary storage medium. Flash drives are good for storing backups or for transferring files, but they simply get lost, damaged, or fail too often to be the only place to store your files.
    #5 2 years ago
    Quoted from ForceFlow:
    How true that is - now I know and never ever will do that again.
    All layouts of my pcbs are lost, WTF - a few years of work simply gone.
    Hope, the pcb manufactures stored at least the Gerber-Files
    Could get a few files back with PartitionGuru (bought the license a few hours ago).
    When I am at home, I will open the stick and solder an USB cable to the stick and look, if the connector is the problem ....
    #6 2 years ago
    Unfortunately it was not the connector, so the ugly fight goes on ....
    #7 2 years ago
    Well... since you said PCB files...
    I'm wondering if you can find a working exact copy and "desolder" the Flash chip and move it to the "good"/"new" part.
    That is assuming the flash isn't built into the controller.
    #8 2 years ago
    Drive Savers. They aren't cheap, but they are really good at data recovery.
    #9 2 years ago
    I generally use ddrescue. You read all of the data off into either an image or another drive, then attempt repairs on the copy. Hard to say if it will help in your case though.
    #10 2 years ago
    have you tried it in something that is running a different operating system? Different version of windows? Just 2 thoughts.
    #11 2 years ago
    I have a certification in digital forensics. Download and install FTK Imager:
    http://accessdata-ftk-imager.software.informer.com/download/?ca1c4cf
    Then plug in the drive and follow this guide to capture an image.
    https://digital-forensics.sans.org/blog/2009/06/18/forensics-101-acquiring-an-image-with-ftk-imager
    Let me know if this is successful. If it is, PM me and we'll attempt data recovery.
    #12 2 years ago
    @all: thanks for the hints - tried with windows 7 and 10, always teh same ...
    Quoted from Crash:
    Thank you so much. Downloadds FTK Imager, but was unable for about 1 hour, to create the image (no source available).
    Look in the following video, how my laptop sees the usb stick for 1 second and then the stick disconnects automatically. In the complete video, the stick is always in and I do not touch it anyway.
    A few minutes ago, I got the chance, that I could select the usv device as a source in FTK Imager. It is now running very very slowly and tries to grab some data in the short seconds, the usb device is seen by windows.
    So that is the status quo, will let it run the whole night now and will report tomorrow morning ...
    #13 2 years ago
    At least you got an acquisition started. Highly unlikely it will complete, but we will see.
    #14 2 years ago
    Quoted from Crash:
    As you said, it did not complete. Instead it always tried to create a new image, when it saw the usb stick for a few seconds. It wrote me hundreds of image files to the destination folder until my drive c: was complete full.
    Tomorrow I will try with a windows xp cd in my office and with a linux live cd (have to create one first).
    When nothing helps, I could send you this fuc.....g usb stick.
    #15 2 years ago
    If the circuitry inside the flash drive isn't allowing it to stay connected at all, you would be wasting your time at this point. To prevent data corruption trying this any further I would send the drive to a professional data recovery service. It will be expensive, but chances are they can transplant the NAND flash IC into another board provided the IC itself is working properly and get your files back.
    #16 2 years ago
    Try plugging it into different computer. Use a PC in one of the rear ports. I have seen flash drives stabilize with a little more current available (500ma rear ports 250ma front ports etc.).
    If that fails send it out for repair or capture from one of the recovery services.
    All is not lost, just expensive to recover.
    #17 2 years ago
    Quoted from pinballinreno:
    I will try that too.
    What do you all think of the following? Use this method
    and after formatting the stick then use a data recovery tool.
    #18 2 years ago
    Ingo, I see you're busy trying to restore your data, but how about replying to my 2 PM's asking about where the board I paid for a month ago is going to arrive?
    #19 2 years ago
    I would strongly advise against formatting. If you wipe out the file allocation table it will make professional recovery much more difficult. Not impossible, but more difficult. I don't think it's a data corruption issue, more like a USB bus issue within the flash drive itself.
    #20 2 years ago
    I agree do not format the drive yet.
    There are plenty of software programs that will raw copy the data and apply the data to a newly formatted track or another drive.
    Paragon 15, will do a raw copy as an extreme measure. I have sucessfully raw copied a drive and used scandisk to make it readable with very little loss.
    #21 2 years ago
    One other thing, sometimes freezing a device or cooling it substantially with freeze spray, can stabilize a drive or controller device enough to copy it.
    #22 2 years ago
    OK, I will not format, but do all the other suggestions. I think now, that it is a "hardware" problem on the stick. I will also try with a bit freeze spray, as the stick indeed is a bit warmer than normal.
    #23 2 years ago
    It's running warm? Could be a malfunction resulting in thermal shutdown disconnecting it. Try freeze spray or putting it in the freezer first.
    #24 2 years ago
    Freezing did not help.
    Mightbe, the following could be interesting:
    With this tool
    http://www.antspec.com/usbflashinfo/
    I got the following results:
    Controller: Silicon Motion SM3257 AA
    Possible Memory Chip(s):
    Samsung K9PDG08U2E
    Samsung K9HCG08U1E *2
    Memory Type: MLC
    Flash ID: ECD7C572 5442
    Flash CE: 4
    Flash Channels: Single
    Chip F/W: ISP 110303-AA-
    MPTOOL Ver.: 2.03.37
    VID: 18A5
    PID: 0302
    Manufacturer: Verbatim
    Product: STORE N GO
    Query Vendor ID: Verbatim
    Query Product ID: STORE N GO
    Query Product Revision: 1100
    Physical Disk Capacity: 16131293184 Bytes
    Windows Disk Capacity: 16115515392 Bytes
    Internal Tags: QT2R-KZ8L
    File System: FAT32
    Relative Offset: 16 KB
    USB Version: 2.00
    Declared Power: 500 mA
    ContMeas ID: D727-02-0F
    Microsoft Windows 10 x64 Build 14393
    Program Version: 8.8.0.600
    #25 2 years ago
    I don't think that information is going to help outside of professional recovery. The flash drive may be shorting out and the PC may be cutting power to the USB port.
    #26 2 years ago
    Just for shits and giggles, how does the USB male connector look on the thumb drive itself? Any corrosion or debris? I used to wear one around my neck for years and they can get a little funky.
    #27 2 years ago
    looks like a failed component see here:
    http://www.sertdatarecovery.com/flash-drive-recovery/how-to-fix-broken-not-recognized-usb-flash-drives
    sometimes you can shotgun a flash drive if you have an exact spare for parts.
    The NAND memory is usually intact.
    #28 2 years ago
    Quoted from mcluvin:
    This isn't the issue, he has already piggybacked an extra plug.
    Came across this company which seems to specialize in NAND chip recovery. They are a US based company though, I would ask if they do business internationally.
    http://www.sertdatarecovery.com/usb-flash-drive-data-recovery
    #29 2 years ago
    Any luck?
    $ 79.95
    pinballmod
    $ 29.99
    $ 129.95
    Mods for your pinballs
    $ 24.25
    The MOD Couple
    £ 39.00
    PinballToys
    $ 123.00
    Little Shop Of Games
    $ 8.00
    Cabinet Parts
    RPGCor
    $ 22.00
    $ 48.00
    $ 44.95
    PinBoss Mods
    Apparel - Unisex
    Pinball Wheezer
    $ 29.99
    $ 29.95
    CzTV Mods
    $ 149.99
    $ 5.00
    Doc's Pinball Shop
    $ 11.95
    $ 135.00
