(Topic ID: 149936)
Help needed Scared Stiff Crate problems
By Flato
  • 3 posts
  • 3 Pinsiders participating
  • Latest reply 3 years ago by mack505
#1 4 years ago
A while ago my crate started acting up occasionally it would not register and then eventually it didn't register at all. I found a post describing a dial underneath to adjust sensitivity i attempted this and now the crate does not register but it does register when you hit one of the leapers. Been playing like this for a while now but i think its about time i try to fix it any suggestions would be helpful. Also i did plug and re-plug some connections when i attempted the fix.
Thanks,
#2 4 years ago
Eddy sensor needs adjustment. With the machine on,locate the eddy board and turn the potentiometer until the led red light becomes solid, then back it off a little and the light will go off. Test with ball.
They can go bad after a while and may require frequent adjustment. Replace if necessary.
Leapers don't have anything to do with crate.
10 months later
£ 79.00
PinballToys
