The goal: Adding in the prototype Vuk back into Radical! ; needing to create a time delayed firing of the coil for the so it will work consistently.
Here’s what I’ve done:
Created a subway and relocated the snake target switch inside the subway .
Installed proper wire form and vuk hardware that works consistently when solenoid is fired to put ball into wire form and back onto Playfield.
The vuk has the fork switch installed.
Problem: there’s no code for the original prototype vuk to fire; hooking into the mpu directly to the tip102 does not provide enough power, piggybacking onto the coil for the snake drop targets is inconsistent and not a viable situation.
Needed: a circuit with possibly a relay to let the fork switch send a signal, then to wait for the ball to settle in the vuk before ignition. I believe the line with enough power is 75v (that I can pull from the drop targets)
Can anyone help a brother out?
