Help! My bingo ate a ball. How do I get under the playfield?
By edhalsim
10 months ago
Stats
  • 5 posts
  • 4 Pinsiders participating
  • Latest reply 10 months ago by edhalsim
Find
Search this topic for posts matching certain words or written by a specific Pinsider. Or both!
#1 10 months ago
Sorry if this is a dumb question. I'm used to newer machines where you just remove the glass and pull up the playfield. How do I remove the playfield so I can find the missing ball? Thanks.
#2 10 months ago
What game?
Chris Hibler - CARGPB #31
http://ChrisHiblerPinball.com/contact/
#3 10 months ago
Quoted from ChrisHibler:
What game?
Looks like he's linked it, I'm sure one of the bingo guys will know. I figure(d) the playfield would lift up like a standard pin as well because if I remember correctly there are some units in the bottom of the cabinet too let alone servicing the bottom of the playfield - but maybe not. I know the heads are usually jam-packed with most of them.
#4 10 months ago
After you remove the playfield glass make sure the screws that hold the playfield in place located close to the edge of the lower cabinet are loosen out all the way. Then pull the ball shooter rod back and out of the way of the playfield and lift playfield upwards at the same time.
Be carefully of the shutter motor unit, cams and switches located on the reverse side of the upper arch of the playfield when lifting up the playfield. If your not careful the shutter motor unit can get caught on the ball return tray and damage it.
#5 10 months ago
Got it. Thanks!
$ 229.99
$ 8.00
Cabinet Parts
RPGCor
$ 89.95
$ 125.00
Lighting - Backbox
Great American Pinball
$ 109.99
$ 46.99
Lee's Parts
$ 69.99
$ 29.99
$ 24.99
Lee's Parts
$ 98.00
€ 9.95
Multigame
$ 69.95
$ 76.00
$ 234.99
$ 69.99
Metal-Mods
$ 69.99
$ 69.99
$ 7,199.00
Operation Pinball
Note: This is an old thread. The last post was made to it 327 days ago. Resurrecting old threads is not necessarily a bad thing, if you think the topic is still relevant and/or your post is beneficial to it (e.g. following up on something). In other cases, it might be better to create a new topic.
Wanna join the discussion? Sign up for a Pinside account, or log in if you already have an account.
