Was installing the mezel mod flashing speaker mod...connected as directed...and the right flasher wasn't working for some reason...then the F10 fuse blew & the Sparky coil started smoking. Turned off, disconnected the speaker mod, replaced the F10 fuse & now the right rear flashers are always on...everything else seems to be fine except for that.
Any suggestions what happened here & how to fix?
Thanks in advance!!!
