Help me repair Data East Pivot Bracket (JP)
OK, one of the Pivot Brackets on my Data East JP was re-mounted by using the wrong size bolts by a previous "tech" and now the threaded mount holes are FUBARed.
What is the best way to repair this correctly? I'm not even sure you to get to the mounting hardware embedded in the underside of the playfield.
This really bugs me and I want to fix it.
Also what are the correct size bolts to use?
Thanks,
RussMyers
