I've been working on repairing a Stern MPU-200 board that came with my project Star Gazer for the last couple of months. Up until now I've tracked progress on my https://pinside.com/pinball/forum/topic/star-gazer-rising/ thread, but I think it's time to get more experienced eyes on this.
I am trying to learn as I go here, which is why I haven't just bought a replacement board or sent it off for repair, so bear with me please.
The board had some mild battery damage along the bottom edge and below the 5101 socket.
I cleaned up the MPU board, cut out the bottom 1/2 of the U8 socket, and removed C8 and C23. These were the only components that seemed to have any contact with the alkaline. I used the toilet bowl cleaner method to neutralize the alkalinity on the board.
I replaced the bottom 1/2 of the U8 socket, and put in new capacitors for C23 and C8. The board trace for U8, pin 8 (ground) was shot so I used a small jumper wire there to work around the missing trace.
Then I added a new large capacitor to replace the orignal battery so the volatile memory will be preserved so long a the game gets turned on relatively often, which is fine for my needs/usage.
Finally, I covered the exposed ground traces with solder to avoid future corrosion.
