I love my RFM because it's smaller than the rest and I can put it in places that others don't fit. I've got mine beside a doorway under an a/c vent that the rest won't fit under. I think you could probably fit one (or a similar smaller pin) along the wall at the base of the stairs/laundry side. Like the back of it facing the stairs and the coin door pointed into the room. You'd still have an aisle to get around, unless you've got a ton of people playing at the top bank of pins. Otherwise I think you've got it at max, because even flipping 3 pins from the top bank to along the left wall still doesn't free up enough space for another pin.
Quoted from emsrph:Is there a better way to arrange the pins to fit more games?
Well, it's not a rearrange but you are welcome to send two or more games to me to free up space. Sweet collection, so I'll let you pick the pins! Best of luck!
I like the way you have the games laid out, it looks good. Speaking of which, wish I had room for more than 4.
............This exists?! I need to try this as well.
You could have one just to the left of the stairs....be a tight fit around everything but I like the idea of storing a couple so you could rotate them.
If you change the storage closet fold-out doors to sliders (or curtains), you might be able to fit a third game there. Remember that you will need to remove playfield glass sometimes, so don't box 'em in too much! For some of mine I need to shift other games a bit in order to completely remove the glass. But it's worth the hassle if you can squeeze in another game!
Just a suggestion but I would try to remove the parts / storage closet and look for like drawers that go under the stairs for storage. Also there has been a lot of designs of game rooms but not many of them feature bars built into the room. In your case I would try to move the laundry upstairs somewhere and utilize that space as a perfect wet bar area. I have a 5' bar in my game room with 40" Lcd tv behind with two leather swivel chairs in front and is a nice area to hang while playing pins with multiple players. I also have a corner dedicated to a sectional seating area for five that I think I use more than the pins and with the bar and wood stove in there I take quite a few naps there as well. Being warm and drunk and surrounded by 7 pimped pins is my heaven here on earth. BTW my game room is attached to a detached garage in the back lot of my residence and is called the Lizard Lounge.
Quoted from flashinstinct:You could stack the washer and drying by purchasing a bracket, then take the space that was occupied by the dryer and make and make shelves....then destroy the closet space and add two more games
I'd go that route.
Those are great ideas. My second parts Flight 2000 pin will probably be moved out to save space.
Eric
Another option without removing the closet is to place x1 machine in the opening where you have suggested storing x2 machines with the coin door facing the coin doors of the x6 machines across the wall.
I didn't know that Icovia had gameroom templates. Neat. Here I've been using Visio like a chump.
The one thing that jumped out at me in trying out their software is that the pin template is REALLY big by default - 64"x34". I thought the average pin was closer to 54"x29" for most SS.
If you've already adjusted the Icovia templates, then my only other suggestion is to provide us the height of your room - bunk pinball machines may be your only option.
Yes the template is a little large, I kept it that way so maybe it will be less tight between machines.
Wayner's idea gave me this iteration:
How much space between facing games allows the glass to be taken out easily? This gives me a foot and a half. Allows for one more game to be set up.
Eric
Quoted from emsrph:Yes the template is a little large, I kept it that way so maybe it will be less tight between machines.
EricGameroom3.jpg 51 KB
There is another thread dealing with removing playfield glass where machines face each other. I liked the concept of just propping the front of the machine from which you need to remove the glass.
I cannot seem to access Icovia. Is it a free download? Thks.
Quoted from emsrph:Wayner's idea gave me this iteration:
Is this a "mainly for you" setup, or do you plan to have other people/groups over regularly? If it is basically just you, then gameroom3 is fine. However, 3.5' for two people back to back is barely any room, not to mention people couldn't get by. If you plan to have people over regularly at all, I would opt for gameroom2. You have the same walkway space, but it only needs to accommodate one player.
I know there is always a temptation to squeeze in one more, but at a certain point not only does it start to look like a horder's place, but it starts becoming less functional.
If you were dead set on getting that 9th game in there, I think flashinstinct's first drawing is the best. If you did blow out the closet, you could get storage containers to put parts/tools in and store them under the game. This would give you 9 games in the most functional layout.
Looking at the layout as depicted I don't think you need even that many pins, 'cause they all seem to have the exact same playfield layout.
Yeah guess I'll keep it more roomy and not pack them in like sardines. Plan to have people over plus these pins will need lots of maintenance TLC after sitting on their butts awhile.
To access Icovia, no download, register here http://furniturelandsouth.icovia.com/
Thx
Eric
It may not look great, but get rid of the Parts / tools closet and put roll out bins under the games.
Could you put the door to the closet on the right side end ? It would be a little tight walking into it but that way you could push those games all the way back to where the closet doors are now?
Or how about just getting like a roll around cart and keep your spare parts and tools in that and when your done with it you could perhaps roll it into the sump pump closet as there seems to be a little room in there for a small cart maybe? Then you could elimate the large closet all together and push the games against the wall and perhaps put a couple of more games down the center area turned the long ways. Hmmm.....??
John P. Dayhuff
Battle Creek, Mi.
269-979-3836
My only advice off the bat is to measure your machines and make sure they're scaled properly. When I used Icovia, the pinball machine is too big and I had to shrink it a bit to match reality.
Probably time to start setting up and seeing how the pins fit. When finished I'll post a pic to compare to the model. Thanks everyone.
Eric
Quoted from Jumping-Box:How about this... It's tight. However it adds three more pins but blocks access to your utilities.
12-pins.jpg 53 KB
Have you considered pin-platforms so you can have 1 pin over another? Doubling your capacity. Think about it. Just raise the ceiling height a few feet if need be.
This page was printed from https://pinside.com/pinball/forum/topic/help-me-fit-more-games and we tried optimising it for printing. Some page elements may have been deliberately hidden.
