(Topic ID: 234195)
Help lord of the rings.
By JHPSWE
  • 5 posts
  • 3 Pinsiders participating
  • Latest reply 3 years ago by JHPSWE
#1 3 years ago
Hi
I can’t understand why my lord of the rings start modes by itself.
I have checked opto and board.
Modes starts random.
#3 3 years ago
Yea sounds like you have a switch registering . Either cold solder joint on opto or just going out . Check also that the connector isn’t loose . Sometimes these can be a little off and cause it to randomly register . You can go into switch test and with the playfield glass off , bang on the playfield alittle and see if that ring switch registers .
#5 3 years ago
Quoted from Phatchit:
Thanks.
I need to change the Italian prom on display so I can understand
Is it only the opto that starts the mode?
I found bad soldering on the switch in the back after the opto.
Can I use opto from a Williams game to test?
