I received my MMr today and it was perfectly protected by the shipping box an looked awesome. I went through the standard set-up procedures, plus the only 2 'Cautions', which was remove the rubber band from the castle towers and snip the two zip-ties to under the PF for the 2 gremlins. Then, I put on the power cord, put the 4 balls inside and thought it was time to play it.
I turn the switch on and nothing happens. It is getting power because I checked another pin in the same power outlet. When I lift the PF I see several very small green LED's glowing but nothing else is on. No GI's. in the backbox, I can see one red glowing LED at the bottom of that small board.
I cannot start a game. So . . . what gives? Never had this to happen before. Is there some other trick I'm not aware of? Any help appreciated.
Mike in Kentucky
