Quoted from thetoyphantom:Ok I tested all the T-Rex switches. I tested all the green wires on the switches using a voltmeter DC and this is what I got.
Top=4.30, Bottom=4.30, Right=4.29, Left=4.29 and Center only gave me 3.27??
The center switch is new and the diode was tested working fine. Why am I only getting 3.27 to the center?
Here's what I suggest:
Test 1:
Rather than measuring voltage, I suggest measuring for continuity with the game off from the wires coming from the connectors at the MPU all the way to the Up switch. If you get continuity, then you know the wiring should be fine (though a pin on one of the connectors could still be questionable, but I'd expect a whole column/row of switches to be flaky if that's the case).
Test 2:
There are two connectors for the switches. I haven't confirmed how they're wired, but one should be the rows and one should be the columns for the switches. The Up switch should have a wire going to each of these connectors. You can check to see if the issue is in the playfield or if it's on the board by disconnecting both of those connectors and manually momentarily bridging a row and a column with a wire. If you know which two pins are the Up switch, you can start the game, get it into switch mode, bridge those two pins and see if the Up switch registers. If it registers, then you know the issue is in your playfield wiring, switches or the connectors. If it does not register, then the issue is on your board.
