Hello,
I am trying to install a shaker motor on my Iron Man Vault edition. On Spiderman there is a plug on the left hand side of the cabinet that plugs into the shaker control board 520-5065-00 supplying power and ground. I mounted the board in the pre-drilled holes but the only plug I can find is a small one labeled shaker ground wire. Where is the other wire or plug?? On spidey it was one plug two wires very simple. Are these new sterns requiring a different board? Confused and I did not buy a kit so no instructions.. Just bought a shaker motor and the little board mentioned above.
Please help,
Rob
