New! Dark mode!
(Topic ID: 266301)
Help identifying/choosing replacement component
By pinheadpierre
6 months ago
  • 12 posts
  • 5 Pinsiders participating
  • Latest reply 6 months ago by pinheadpierre
#1 6 months ago
I’ve got a couple of these that need replacing on standup targets on a Seawitch. I want to make sure I’m identifying the part correctly and ordering a suitable replacement.
I’m reading this as being a .05uf 100v ceramic disk capacitor. Is that right?
The closest thing I’ve been able to find at Mouser is this:
https://www.mouser.com/ProductDetail/Vishay-BC-Components/S503Z69Z5UL63L0R?qs=sGAEpiMZZMuMW9TJLBQkXqj3fRP1vh7ODUDs1pw0e7Q%3D
It’s a higher voltage unit, but that should be okay, right?
#2 6 months ago
Yes, you can go higher voltage
#3 6 months ago
.05Mf not .05uF
#4 6 months ago
Quoted from chas10e:
.05Mf not .05uF
I thought the M after .05 was the tolerance? (20%)
#5 6 months ago
Either is ok
#7 6 months ago
Quoted from jj44114:
Either is ok
Huh ... guess I learnt something https://www.westfloridacomponents.com/blog/is-mf-mfd-the-same-as-uf/
thanks .... a higher voltage rating is ok
#8 6 months ago
Quoted from QuietEarp:
Can you use a .047 like they use on Bally machines?
ebay.com link » 100 Pcs 047uf 50v 20 Z5u Axial Ceramic Mlcc Capacitors Sa055e473maa Avx
Recommended from this thread
https://pinside.com/pinball/forum/topic/replacement-switch-capacitorolder-bally-pins
I could be wrong (which is why I’m asking for advice), but those are a lower voltage rating. I think you can go higher voltage rating, but not lower?
#10 6 months ago
Yes, but these are for stand up targets.
#11 6 months ago
Quoted from pinheadpierre:
You are correct here based on the original components but I was wondering if the original component was a higher voltage than it needed to be. Older Ballys and older Sterns share a lot of similarities and you can use the same mpus on each so I assume the voltages may be similar as well. Can someone with more knowledge confirm or deny this?
#12 6 months ago
Found an exact replacement (.05M 100v) on EBay. Thanks for pointing me in that direction. It seems that these capacitors are used in Fender guitars as well.
$ 50.00
$ 149.00
$ 12.00
Third Coast Pinball
$ 119.95
Allteksystems
Third Coast Pinball
3,750
Bellefonte, PA
