I just got my first pin, a 1965 eager beaver. Work well and am currently tuning it up making sure everything works. There is a bell on s continuous stepper unit (label peeled off unit, not sure what it does) and what looks like a clapper arm that looks like it hits the bell at every advance. Only issue is it does not reach the bell. I tried adjusting the bell as close as possible but no luck. On the Internet pin database I found a photo of the light box where this stepper lives and noticed the clapper arm has some additional ring on it which might be why mine does not reach. Could it be o-ring or rubber portion? Plastic ring? I am new to pins so have no idea. I attached the stock photo of the pin. The piece in question is the small lever above the bell on the left. Mine is just a small metal ring whereas the photo looks to have some white, larger diameter object attached to the arm.
