(Topic ID: 133342)
Help ID Upgraded system 3 CPU
By 04barb
  • 6 posts
  • 3 Pinsiders participating
  • Latest reply 3 years ago by viperrwk
    #1 3 years ago
    Hello,
    I think I have an upgraded system 3 cpu board, however I don't see the cut and jumper that should be there. Can anyone help?
    #2 3 years ago
    That is a system 4 MPU (there is a horizontal IC socket under the batteries).
    #3 3 years ago
    I see so the board began life as a system 4 and was not upgraded? I just suspected it was because its in a Aristocrat shuffle alley, but the driver board says it was in a firepower. Also, I need to replace the CPU, because I replaced the socket and installed the chip in backwards. What CPU chip does it take? System 3 calls for a 6800 but since its a system 4 would it call for a different one?
    #4 3 years ago
    system 4 uses a 6800 cpu chip.
    The WMS mods specified to be done to a s4 chip is in the reset section and around around the clock crystal. I see the reset mod has been done, i can't tell about the clock mod. The clock mod adds a cap around the clock circuit.
    #5 3 years ago
    thanks for the info
    #6 3 years ago
    The Disco Fever (last Sys3) schematics on IPDB do show two different versions of the schematic and the BOM - there's an optional socket for IC26 below the batteries and the schematic is marked "3A". This shows a 3.3uf tantalum cap (C27) in the reset circuit:
    http://mirror2.ipdb.org/files/686/Williams_1978_Disco_Fever_Schematics_paginated.pdf
    The changes to the reset circuit are in the manual amendment:
    http://mirror2.ipdb.org/files/686/Williams_1978_Disco_Fever_Manual_Amendment_16P_482_110_September_1978_bad_copy.pdf
    where C27 is removed and other changes are made.
    This essentially turns the late 3A board into a Sys4 board. Early Sys3 boards are missing the socket at IC26 entirely as Andrew indicated. Your board does not have C27 indicating the reset circuit has been upgraded.
    The base board p/n for Sys3A and Sys4 is the same - 1B-2001-133.
    Early Sys3 board:
    http://ipdb.org/showpic.pl?id=686&picno=16660
    Sys3A board:
    http://ipdb.org/showpic.pl?id=558&picno=16642
    Sys4 board (socket included for IC26):
    http://ipdb.org/showpic.pl?id=1780&picno=19197
    viperrwk
    $ 99.00
    Hardware
    Pappy's Pinball Palace
    $ 149.99
    $ 49.00
    $ 29.99
    $ 1,000.00
    $ 36.99
    Lee's Parts
    £ 29.00
    PinballToys
    $ 38.00
    $ 79.00
    $ 229.99
    $ 22.00
    $ 9.99
    $ 369.00
    $ 115.00
    Cabinet Parts
    Merf's Pins
    $ 79.00
    $ 60.00
    Docquest Pinball Mods
    pinballmod
    $ 44.99
    Lee's Parts
    $ 43.00
    Pin Mods
    Metal-Mods
