For years now my Lethal Weapon 3 pinball game's pop bumpers only activate when the ball hits them with medium or hard contact. Soft contact and the ball just rolls off them and the pop bumpers don't activate. So I did some research and decided to try adjusting the switches on them. Two of them seem better now. But the third one went from weak to completely dead. I did the game's switch test and confirmed the switch won't closed. The coil works but the switch itself doesn't trigger the coil now at all. Since I was trying to adjust the switch and it went from working to dead it surely seems like I damaged the switch when trying to adjust it. Before I order a new switch and swap it out I'm wondering how to verify it's a bad switch.
I can see where the plunger on the playfield hits the switch. Is there a way to move up the switch a couple inches with a screw driver or something touching both leads and thus closing the switch and making the coil fire? Or is there a better way? I'm a novice at repairing my pinball game. thanks for your help. I appreciate it very much.
