Had one given to me from a barn find. hod do I remove the playfield glass to get into it?
Open coin door, look to right side or along the top edge, look for any handle or anything the pulls or moves to unlock the lock down bar.
LTG : )™
Open up the front coin door.
Reach in and slide the lockdown bar lever near the top righthand inside the game towards the left.
Remove lockdown bar and slide glass off carefully.
Instead of a lockdown bar, they may have just used two small bolts. Check to see if there is a small bolt and nut hanging down from the lockbar. A lot of older Gottlieb's used this method. After you get the lockbar off and the playfield glass removed, you may discover that the playfield is actually screwed from the top down. It won't lift up until you remove the 6-8 screws holding it down. Good luck.
This page was printed from https://pinside.com/pinball/forum/topic/help-how-to-remove-play-field-glass-on-60s-palooka and we tried optimising it for printing. Some page elements may have been deliberately hidden.
