I have a Warlok, and recently noticed that the bottom screw on the right slingshot was leaning in towards the centre of the slingshot (the rubber was pulling it in).
I took the cap and rubber off, and un-screwed the 3 posts that form the points of the slingshot. Underneath the bottom post, I found the problem, the hole the post screws in to has been drilled twice, in slightly different locations, and now the 2 holes are merging into 1 large hole... see attached image for a much clearer description:
My question is what materials should I use to fix this? and are there any particular techniques I should use?
I'm in the UK if that makes a difference in available materials.
I'd be very appreciative to any help given.. I miss playing my Warlok!
