(Topic ID: 182952)
Help, Gottlieb Sys 80 lamp test issue
By Troyster42
7 years ago
#1 7 years ago
Hi all, I’m in a bind here and not sure what is wrong and help will gladly be appreciated. I have a Gottlieb sys 80 Mars God of War. When I go to test 16 to do the lamp test I am getting to me really odd results. First its starts off pulsing each Lamp twice, I’m not sure of that’s normal or not, I would thank not. It will do the Q relay , then the Tilt rely, the coin out relay all two times each. Now it does the ramp holds that on and about a half a second later the ball release engages. Then the ramp will disengage and about a half second later the ball release will do the same. This will keep repeating for a long time until they stay on and I have to turn of the machine. Now when it starts engaging the ramp all of the lights start like its in attract mode too. Up until this part no extra ball lights or shoot again lights have come on, I think they are L2, and L3. Now with all of the lights flashing they are working as well. When I turn the machine on none of the extra ball or shoot again lights are on, after looking at some videos I think that is normal for those lights not to be on in attract mode. I have replaced Q1,Q3,Q4,Q13 and Q42 on the Driver board as they tested bad. I hope some one has an idea what could be the issue or where to look.
Thanks in advance.
#2 7 years ago
Shoot again will not light in attract mode.
#3 7 years ago
Thanks, any idea whats going on when I try and run the Lamp test?
#4 7 years ago
I'm wondering if what I am seeing is how this test should go, and I am just not waiting long enough for the coils to disengage? In the manual it says the two relays are pulsed and the coin lock out, then all the lamps, ball release ramp and right ball launch are sequentially turned on. This is what its doing minus the right ball launch. I was thinking it would just turn one lamp on then off and move on instead of doing them like a wave over and over. Can someone confirm this?
#5 7 years ago
Yes tests are very limited it sound what you are seeing is correct.
16 is a few relays and then all lamps, 17 is coils which on Black Hole I think manual is incorrect and some numbers are skipped but all should get fired, 18 is switch and 99 is seen if all switches open so no balls in trough and all drops up. 19 is displays
On some tests IE coils if you hit start you can hold and retest same coil over and over or stop digits on display.
But all in all if you are used to other manufacturers you will be disappointed with Gottliebs tests they are very limited.
#6 7 years ago
Thanks, CNKay I have been beating my head in the wall trying to figure what was going on, then I looked at the test a different way and thought this could be what is expected. This is my first Gottlieb pin and I wasn't sure what to expect, like you said other manufactures tests seem to be a lot more detailed. Not to got the one top right coil repaired and I should be up and running.
$ 83.00
PinballReplacementParts
This page was printed from https://pinside.com/pinball/forum/topic/help-gottlieb-sys-80-lamp-test-issue and we tried optimising it for printing. Some page elements may have been deliberately hidden.
