Expert help needed...
Finally got everything working on the Gorgar. After playing a couple of games, it seemed that the flippers were a bit weak. As a result, I decided to take the coils out and replace the sleeves with plastic sleeves, clean the parts, and re-install. Also cleaned the EOS switches and the switches on the buttons that activate the flippers during game play. After all the work was done, I turned on the game to give it a try. The flippers did not work at all while everything else worked fine. Checked the fuse on the power supply... blown! I noticed that someone had put a fast blow fuse in prior and so I replaced it with the proper fuse (10A slow blow). Turned the game on, still the flippers are not working and the fuse did not blow. ? I have noticed that when I hit the flipper buttons on the side of the game, the playfield lights dim just a little. Could this be an issue with the diodes on the coils? Wanted to check the experts before getting too far in the weeds trying to guess the issue.
Thanks in advance ...
