I recently bought a Sonic Super Straight with a beautiful playfield (wish all the manufacturers made them that durable), and a really nice backglass, but also the all-too-common apparently water- or humidity-damaged particle board cabinet. It was falling apart in pieces at the bottom of the side panels. I didn’t take photos, but these were taken by the seller, so you can get an idea of the condition (before more of it came off in the back of my vehicle).
CD908494-A98A-4BD5-BFDB-D07917761334 (resized).png12F99AD1-9C77-40EB-AD14-4D0E95B29BA6 (resized).png
After searching the web, I discovered some items made by PC Products to help this cabinet. I got them at two different local hardware stores.
First, I applied PC Rot Terminator, which is a two-part liquid epoxy designed to treat rotted wood. It soaked in and turned the flaking mess at the edges of the particle board into a solid hardened material. I made many applications, probably more than necessary, and was pleased with the solid result.3C00BA78-F1C9-468D-8EBD-13D1AD818D37 (resized).jpeg
Then I used their PC Woody two-part paste epoxy to fill in the areas that had flaked away. I got the larger cans. My hand is in the photo to show the size of the containers; they’re not really that large. I got two sets, and I used most of it.83F65816-914E-45B2-B069-24B15CDF4DDD (resized).jpeg
I didn’t take photos along the way, but here is the cabinet after touching up the repaired areas. This is not high-end by any means, but the cabinet is solid, definitely looking better, and I’m confident that I could load and transport it without pieces flaking off.459855B8-3D74-48C6-8C4A-7B3AF9D9CE72 (resized).jpeg
