Not sure what cables you reseated, but this seemed to fix a similar problem here:
https://pinside.com/pinball/forum/topic/dmd-display-issue-vertical-lines-#post-6529585
I just had a similar looking problem tonight, and reseating my ribbon cables solved the issue. One seemed to have shaken a little loose, and I suspect that was the issue.
Replace the cables. They are over 30 years old and most likely have internal corrosion.
Re-seating them will probably work but it isn't a fix. The problem is likely to return.
This page was printed from https://pinside.com/pinball/forum/topic/help-dmd-issue and we tried optimising it for printing. Some page elements may have been deliberately hidden.
