(Topic ID: 257184)
Help converting MPU-200 for a MPU-100 game - Nugent
By action76
1 year ago
  • 7 posts
  • 5 Pinsiders participating
  • Latest reply 1 year ago by Quench
  • Nugent Stern Electronics, 1978
#1 1 year ago
I am trying use a MPU-200 board in my Nugent machine that has a bad MPU-100. I would like to use the roms from the original board and re-jumper the MPU-200 to use them. The question is what type of chips are the original Nugent masked ROMs? I assume they are 9316's but if that is the case, there is only two, (a black one in U2 and a white one in U6), and the chart below I got from pinwiki, does not cover that situation. Do I use the 2716 two ROM configuration or something else? If anyone could shed some light on this issue, it would be greatly appreciated.
#2 1 year ago
assuming they are 9316 PROMs you want the 2nd line and only put the chips at u2 and u6. Double check they are actually 9316 before you start changing jumpers.
also need change the clock speed to jumpers and remove u13 ram.
#3 1 year ago
I would also make super sure that the MPU-200 board is working before you start changing jumpers. It may save you some time down the road.
#4 1 year ago
Quoted from barakandl:
How can you tell what it is? The ones I have do not have the chip type numbers on it only has the stern 25A-P8-U6 game numbers on it.
#5 1 year ago
If there is no window on it and it's just a black chip with the game numbers, it's a 9316.
You can avoid changing jumpers if you have an eprom burner, u2 from nugent would go into u1 on the mpu200, u6 from nugent would go into u5 on the mpu200, and you'd put a copy of u6 into u6. That's if your mpu200 is currently set up for 4x2716. If it's set for 2x2732, you'd burn nugent u1 for u2, and double up u6 to burn into a 2732 for u6.
#6 1 year ago
Quoted from slochar:
Thank you for the clarification. I thought that was the case but was not positive.
#7 1 year ago
I haven't done what you're doing but I'm pretty sure you will need to remove the 5101 RAM chip at U13 since Nugent software will expect it not to be there.
