(Topic ID: 225408)
Help Burning a Stern Rom
By Lonzo
5 years ago
  • 10 posts
  • 5 Pinsiders participating
  • Latest reply 5 years ago by Lonzo
#1 5 years ago
I've been burning my own roms for my restorations for years. I have a buddy that has a Roller Coaster Tycoon that has old code on it. I have never burned a whitestar rom. There must be something you have to do with the rom file before you burn it as I have tried 5 times and I cant get the machine to boot. I did a search and I found a thread that mentioned a boot file or something that used to be on the Stern website but they took it down.
Can someone explain what needs to be done to burn a rom on this system?
#2 5 years ago
Some information on RGP indicates that the boot flash rom is U7 - which is buried inside the RCT file from stern in the 'pinball' folder.
AFAIK whitestar images are just burn on the correct eprom and go. It boots with the older code still?
#3 5 years ago
What is the file size of the ROM and what is the ROM size you are trying to burn?
If the EPROM chip is bigger than the binary file, you need to fill the ROM chip with repeated copies of the binary file. If the binary file is bigger than the EPROM chip you need a new bigger EPROM chip.
#4 5 years ago
Quoted from barakandl:
I’m using the chip the manual says to use.
#5 5 years ago
it uses a 27c4001 for display and a 27c1001 for cpu
#6 5 years ago
Quoted from Astill:
The manual says the CPU and display are both 27C040. Of course it wouldn’t be the first time a manual had been wrong.
#7 5 years ago
Quoted from Lonzo:
The CPU rom size is 128k so you need a 27C1001 or 27C010 to burn the file directly.
You will need to quadruple up the rom file for your 27C040 or double it twice.
#8 5 years ago
Quoted from snakesnsparklers:
When you say quadruple it. How exactly do you do that?
#9 5 years ago
I create batch files to run command prompt strings to combine ROM files.
Example turning 27c010 image file into 27c040. The starting file will be a 1mbit (27c010) in size and named ROM.1MB for example.
Fire up windows program notepad and copy the single line below into it.
copy /b ROM.1MB+ROM.1MB+ROM.1MB+ROM.1MB ROM.4MB
Save that notepad file as COMBINE.BAT (the .bat at the end is important, it can't be .txt or whatever) in the same folder as ROM.1MB
Run COMBINE.BAT by double clicking on it and it should create a quadrupled up image ROM.4MB.
Some eprom burning software has ways to fill up a larger eproms. For GQ-4X you can set device to to 27c010. Load the rom. Select all and Copy. Set device 27c040. Select all and delete. Then use the paste command four times to fill up the 4x larger EPROM.
#10 5 years ago
My buddy pulled the sticker off and it was a 1001 so I guess I can burn it directly. I use the GQ-4X so I can try to do what you explain if I have a problem in the future. I guess I have never ran into a situation where the size want right.
I appreciate the help.
$ 6.00
Apron Envy
3,950
Little River, SC
$ 8.00
Tools
Nezzy's Pinball Prints
$ 1.29
Daddio's 3D Printed Mods
$ 18.95
$ 54.99
$ 45.95
$ 1.00
Pinball Alley
Medford, NJ
$ 5.95
The Pinball Scientist
$ 17.00
Nordic Pinball Supply
PinSound
$ 22.00
arcade-cabinets.com
3,999
Nashua, NH
$ 76.00
Lighting - Backbox
Arcade Upkeep
Great pinball charity
Pinball Edu
This page was printed from https://pinside.com/pinball/forum/topic/help-burning-a-stern-rom and we tried optimising it for printing. Some page elements may have been deliberately hidden.
