Hi All,
So, I've got a 1975 Chicago Coin Blue Max pinball. It's been working well, but for some reason, the tens stopped scoring. When the ball rolls over something that is worth ten points- nothing. All other scoring is working.
A couple things I've checked:
- The tens relay in the back box is not stuck on. If I manually press the tens relay, the tens reel will advance and the chime will ring.
- The wiring to the tens switches seems to be good. I don't notice any wires that have come loose.
Can you give me some advice? What should I check next? Any idea why the tens would just stop scoring?
Thanks in advance!
Barky
