Help, Best crimp tool for repinning connectors?
(Topic ID: 182234)
By Mark66
1 year ago
  • 32 posts
  • 17 Pinsiders participating
  • Latest reply 1 year ago by Budwin
  • Topic is favorited by 11 Pinsiders
There have been 7 images uploaded to this topic. (View topic image gallery).
#1 1 year ago
I need your professional opinions on the best crimp tool for repining connectors on a early Bally SS pin. Best brand and or where to purchase. Thanks, I know there has been some past suggestions on other threads cant seem to find them. Any help is greatly appreciated. Any links would be great.
#2 1 year ago
I'm not a professional by any means, but I've been using my Waldom branded crimpers for quite some time, and it hasn't led me astray. I've successfully crimped entire games (mostly Gottlieb System 1s) with them with no troubles. I picked it up at Great Plains Electronics, model W-HT-1921.
https://www.greatplainselectronics.com/products.asp?cat=138
For the larger .156 connections you see on rectifier boards, you'll want to pick up the red handled crimper (although, I've used my crimper for the larger connectors with no troubles--you just have to be more careful. Probably not recommended to do, but it works in a pinch.)
#4 1 year ago
I've got the expensive and the cheap and this is the one I always use now:
amazon.com link »
#5 1 year ago
Quoted from hailrazer:
amazon.com link »
hailrazer Is this for the .156 or .100?
#6 1 year ago
Quoted from arcademojo:
I got same one (HT-225D) and it does both
#7 1 year ago
Get these
#8 1 year ago
Quoted from chas10e:
So it has 4 different sizes? Wire and instillation on both sizes?
#9 1 year ago
2 .... it crimps the conductor and the strain-relief at the same time for both sizes
#10 1 year ago
Awesome! Thanks.
#11 1 year ago
Ok a little off topic but, is there a tool for these connectors? The little screwdriver just doesn't seam right.
#12 1 year ago
I would think a "punch down tool" for telephone/communication for IDE headers
https://en.wikipedia.org/wiki/Punch_down_tool
#13 1 year ago
Marco's website isn't working right now, but here's the tool you'd want from pinrestore. It's about halfway down the page.
http://www.pinrestore.com/Tools.html
#14 1 year ago
Quoted from mbaumle:
Thanks, I seen one a while back that had handles like a pair of pliers. Haven't been able to find it again.
#15 1 year ago
I use this one from ebay 181112865104 looks the same as the HT-225D, but with three sets of dies, and does a good job. Close the jaws a little bit and the ratchet holds the terminal and then feed the wire in then the crimp does the conductor and strain relief simultaneously. Does 0.156 and 0.100" terminals.
#16 1 year ago
throw those in the garbage and use the molex ones. 10x's better. These are just crap.
And the crimper that pin restore sells is top notch. it's expensive. But I have yet to ever have a bad crimp from it. You do NOT want to go cheap in this department. Just going to leave you frustrated.
#17 1 year ago
Absolute best crimpers are Certicrimp crimpers from AMP. Those generally start in the $300s and aren't found in a lot of places.
IMHO - best crimpers are the ones with locators such as the Molex HTR2445A (Sargent 3136CT). No holding the pin - push up tab, drop pin in hole, release tab. locator holds pin in proper place. Locator doubles as a wire stop to keep you from inserting wire too far, crimper then crimps both wire and insulation at same time. But these crimpers tend to run $100+. You can OFTEN find them on ebay at <$40 per pair.
The sub $50 crimpers -- this tends to be a Ford versus Chevy type issue. Lots to pick from - some suck ... some work quite well. But I don't use any in this category - I bought a full set of Molex crimpers off ebay.
#18 1 year ago
amazon.com link »
^^^^ Yes ^^^^^, you want the ratcheting type: HT-225D . This is a good one. I bought the regular type and it was tedious to work with.
#19 1 year ago
Well all of you well informed have been a huge help, the HT-225D it is.. I had checked this one out on Amazon, just wasn't sure it was the right one. Thanks for all the recommendations and help!!
#20 1 year ago
amazon.com link »
Not saying the crimper is bad, but according to the description, it's only for 3 and 4 pin Molex Connectors.
#21 1 year ago
... so if it's a 2 pin connector, I'm hosed?
#22 1 year ago
Quoted from G-P-E:
Exactly!
#23 1 year ago
I don't know what you mean...but then again I only use trifuricon pins, so the size of the connector is not relevant.
#24 1 year ago
If you're going to be doing a lot of those a good ratcheting tool is a must, but if you don't use them often or only for a few connectors, these are fine:
There's one for .100 and .156 spacing connectors. Just don't use a screwdriver or something else with a blade edge. it's sloppy, can damage the connector and you can hurt yourself.
#25 1 year ago
Quoted from Mark66:
I did a whole video on the repin process using these crimper. They are great. Here is a link to the video and the crimper. Hope this helps.
amazon.com link »
#26 1 year ago
amazon.com link »
Will this work with both 22-26AWG wire (Smaller wire size), and 18-20AWG size wire (Larger wire size)?
#27 1 year ago
Ok simple question. What is correct length of exposed wire? 1/2 1/4?
#28 1 year ago
Quoted from pinlink:
The link says 28 to 18 AWG.
#29 1 year ago
Size it based on your connector. It should protrude slightly beyond the crimp, but not far enough that it would impede the connector's action.
#30 1 year ago
Yes it has 2 crimp sections, one for 18-20 and one for 22-26
#31 1 year ago
Quoted from G-P-E:
I have both Sargent 3136-CT for .156, and Sargent 3135-CT for .100
They are kind of spendy at $110 ea but worth every penny IMO. got them at Great Plains Electronics. Nice tools made in USA!
#32 1 year ago
There are ratcheting tools from AMP that work well.
Get off eBay cheaper.
Amp TE Series = Molex
https://pinside.com/pinball/forum/topic/wtb-williams-cpu-board-connector-j209
Pistol Grip: Tyco/AMP 58074-1
0.100" Crimp Head : Tyco/AMP 58246-1
0.156 Crimp Head : Tyco/AMP 58247-1
€ 3.95
Multigame
Third Coast Pinball
$ 7.65
Cabinet Parts
Third Coast Pinball
$ 149.00
Medford, NJ
