Finishing up a Bally Xenon for Expo. All issues were gone, and had everything working. Decided to replace the ratty power cord. On first power up after that (several quick power cycles due to crappy power strip connection), 23 (maybe more) of my playfield controlled lamps are out! This also affected half of the surround lights (numbers 5, 6, 7 & 8 on all four sides). There may be some more on the backbox - I did not note every one, but most of the playfield is correct.
I did check several of these - they all lit fine when grounding the lamp board transistor's anode. That would seem to indicate a bad transistor - but not so many of them at once! Plus, there are lights out driven by the Aux Lamp Board too.
So, it must be upstream? It is not just one decoder out - there are outputs from every decoder leading to the lamps that are out. I made a quick chart with lamp, connector & pin, transistor number, and decoder and channel. See below. But I am not seeing a logical pattern yet - but maybe one of the address lines feeding those decoders? Maybe back to the MPU?
Anyone seen something like this? Full disclosure - I did do some soldering on some of the lamp sockets, but everything was OK until I shut down to replace the power cord. I have scanned for potential solder splatter, but have not found any yet.
Thanks in advance!
