(Topic ID: 275008)
Help : Bally Fireball Classic 1 amp playfield fuse blowing on power up
By Atariforever
#1 3 years ago
This Fireball Classic machine had some issues when purchased and all have been solved except one..Problem is with the 1 amp SB fuse blowing on initial power up of game..
First of all the game boots up and plays fine. New Alltek Ultimate CPU board. New Alltek lamp board.
All scoring / targets/ displays/bumpers/ flippers/etc are working fine; the only issue is the under playfield 1 Amp SB fuse.
I may have it narrowed down the problem. But need a little help solving the issue.
This is the scenario of the problem
--When i unplug the solenoid expander board and power up the game; the 1amp SB playfield fuse does not blow- the game plays fine except for the spinner not working.
--When i plug in the solenoid expander board and power up the game;the playfield 1amp SB fuse blows - the game still plays fine; the spinner works fine but the pop bumpers/kickers work at a reduced power.
I have replaced the original solenoid expander board with a newer "Great lakes Modular" version with the same results.
I have repinned the connector to the solenoid expander board. All wires match up with the original with the same results
I even have switched the original Solenoid Driver Board with a new Alltek Solenoid Driver Board - still the same results
In a nutshell- To play the game you either have the spinner working and have half power on the playfield because of a blown fuse or replace the fuse and unplug the solenoid expander board and play the game at full playfield power with no spinner.
Have anyone got a suggestion
thanks
#2 3 years ago
One of the coils driven by the solenoid expander has a problem.
#3 3 years ago
On second thought, Fireball Classic doesn’t have a spinner or a solenoid expander Board
#4 3 years ago
Quoted from jj44114:
I think he means the motorized "Spinning disc"
the "solenoid expander boards" are tiny boards that drive the flashing pop bumpers
I am not sure how they are related ..... is the connector keyed correctly on these tiny boards?
#5 3 years ago
Yes the "spinner" in my post is the spinning disc in the center of the playfield. Sorry for any misunderstanding.
The solenoid expander Board is the little board under the back of the playfield
#6 3 years ago
This suggests there should be a lamp socket near it and needs a good bulb http://techniek.flipperwinkel.nl/ballyss/rep/index3.htm#expand
#7 3 years ago
Attached are two short video clips showing the solenoid expander board working in the attract mode and also during the lamp test mode. I have a newer version of the solenoid expander board installed and i was told that that the 555 bulb does not even need to be installed or working due to the improved design of the newer board. The board seems to working correctly- the blinking light /clicking/ spinner working without the 555 light on. Am i correct?
Maybe my issue is not in the solenoid expander board; but in a coil associated with the solenoid expander board.
Does the solenoid expander board in Fireball Classic control any of the secondary coils as well or is it just the "center spinning disc" ?
All coils seem to work fine in the solenoid test mode.
Attract mode :
Lamp test mode :
#8 3 years ago
Is the ground braid properly attached in the head?
The schematic shows the fuse for the spinning disc on the transformer assembly
Did you place the wire correctly into the connector after re-pinning , is the rejection key in the correct place ?
Bally Fireball Classic sol ex board (resized).jpgBally Fireball Classic sol ex board (resized).jpg
#9 3 years ago
Thanks for the help ;I have looked at your ideas.
The ground braid was not attached in the head? Completely missed that one --see pictures for before and after . After I reattached the ground i tried a new fuse and it blew again- no difference.
The power module fuses in the bottom cabinet are all good. There is no 1 Amp SB fuse in that module. Unsure about that schematic posted. The only fuse affected is the under the playfield 1amp SB.
I have reexamined the wiring to the connector that was redone. I followed the same wire placement as the old connector had. Attached is a before picture and an after picture. They look the same to me .
dangle ground (resized).JPGdangle ground (resized).JPGno ground (resized).JPGno ground (resized).JPGground reattached (resized).JPGground reattached (resized).JPGold SEB board and wiring placement (resized).JPGold SEB board and wiring placement (resized).JPGnew SEB wiring placement (resized).JPGnew SEB wiring placement (resized).JPG
#10 3 years ago
Can you post a picture of the transformer module?
Would be interesting to see where the spinning motor power wires come from the transformer especially their wire colors.
Some solenoid expander boards (SEB) have the solenoid 43V connected to one of the switch legs on the relay with a wire link. Essentially this link wire connects pin 4 to pin 9 on the plugin connector. This causes havoc with some games when the link is installed when it shouldn't be.
Your original SEB shows that wire link is cut which should be right (you can see the cut jumper link between the diode and the relay on your old board).
Does your replacement SEB have any jumpers links?
Where the yellow-white and yellow-red wires for the spinning disk motor connect at pins 4 and 5 on the SEB, do you measure any continuity to other pins on the connector (other than potentially pin 7, there should be none).
#11 3 years ago
#12 3 years ago
The New SEB used
#13 3 years ago
Quoted from Atariforever:
The power wires for the spinning motor come off the transformer which we don't have full view of in that picture. I can see a yellow-red wire top right corner but can't see where they come from.
Can you post a pic showing less of the rectifier board and more of the transformer?
Is there any instructions with this SEB on how to jumper it?
#14 3 years ago
A closer look at the new SEB with the JMP 1
The transformer picture i will get shortly
#15 3 years ago
is this picture any better
#16 3 years ago
If you measure continuity between pin 4 and pin 9 on the connector then you need to cut that JMP 1 jumper. It's connecting solenoid DC power to the spinning disk motor solenoid AC power which is wrong for this game.
#17 3 years ago
See the previous post about the SEB.
In your second picture there is a floating two pin connector with yellow-black and yellow-red wires on one side, and yellow-red and thick red wires on the other side. That connects the transformer to the playfield spinning motor.
The thick red wire has a black cylindrical thing on it which actually contains the fuse for the spinning motor.
#18 3 years ago
unfortunately i'll have to check later- i have to go to work now.
i wish i had more time .....
.i will check that fuse as soon as i get back thanks for now
#19 3 years ago
Keep in mind the solenoid expander is not being used for that function in this game. Instead it's being used as a relay to turn the spinner motor on and off. To that end the jumper makes a difference. I packed away my schematics because I'm moving but if somebody would post the solenoid expander schematic we can see how the board jumper should be set.
#20 3 years ago
Quoted from BigAl56:
Hi @BigAl56, the online Fireball Classic schematics are missing the SEB schematic - not sure if they're in the real paper schematics.
What I can tell from the pictures above:
The fused motor wire connects to the orange wire on the transformer which is solenoid 43 volts AC. This leads directly to the spinning disk motor as the yellow-black wire.
The yellow-red wire connects to the other transformer solenoid 43 volts AC wire which is green.
This yellow-red wire goes to the playfield at pin 4 of the solenoid expander which is the relays common switch arm.
Pin 5 of the solenoid expander is the relays N.O switch contact and connects to the motor as a yellow-white wire.
Pin 9 on the solenoid expander is 43 volts DC used to power the relay.
If pin 4 is jumpered to pin 9 on the SEB then this is shorting the 43 volts DC (after the bridge rectifier) to the 43 volts AC (before the bridge rectifier).
In my mind, that jumper on the SEB needs to be removed so the relay switch is isolated from the DC side of solenoid power.
The picture of the original SEB above shows that jumper is cut.
#21 3 years ago
-- I checked the fuse in the floating two pin connector in the cabinet next to the transformer and the fuse was fine. Not blown.
-- I checked for continuity between pin 4 and pin 9 on the connector and could not get any continuity.
-- I reread my old notes from a previous repair attempt late last year and it looks like the original SEB did have the jumper attached; and i cut it off to try the original SEB board in the machine without the jumper.
#22 3 years ago
Quoted from Quench:
Have you checked this ^^^ with the SEB installed?
#23 3 years ago
i could not get any continuity on those pins noted . No continuity on pin 7 as well.
Continuity test- power off in machine-- diode setting on meter-- one lead on each area noted - correct ?
#24 3 years ago
Below is the solenoid expander schematics on Fathom and Centaur.
When the relay is Off, pin 4 is switched to pin 7.
When the relay is On, pin 4 is switched to pin 5.
The Fathom setup shows the purpose of the jumper is to connect pin 4 to pin 9 (which is 43V DC solenoid power). This setup switches solenoid 43VDC power between two banks of solenoids on the playfield.
You need to cut that jumper on the SEB for Fireball Classic. It's shorting 43VAC coming in on pin 4 to 43VDC which is coming in on pin 9 and is causing the playfield 43VDC solenoid fuse to blow.
Scroll down to @barakandl's solenoid expander board on this link - you can see it specifically states to cut the jumper for Fireball Classic.
https://nvram.weebly.com/new-pcbs.html
To check the continuity previously mentioned:
Machine OFF.
Set your meter to low ohms range.
Touch both meter leads together - the multi-meter should show near zero ohms indicating continuity.
Put one meter lead on pin 4.
The other meter lead on pin 7 should make the meter indicate near zero ohms for continuity.
Move that meter lead from pin 7 to pin 9 and you should again see the meter indicate near zero ohms (assuming you haven't cut the jumper yet).
#25 3 years ago
just checked the continuity from pin 4 to pin 7 -it did show show zero ohms
just checked the continuity from pin 7 to pin 9 -it did show show zero ohms
i will now go cut the jumper and see what happens
#26 3 years ago
I cut the jumper in the new SEB. Turned on game and the fuse did not blow......
Everything worked perfect. The spinner and full playfield power.
Thank you very much for the help in getting this game to 100%
#27 3 years ago
Cool.
And there were no instructions that came with the new solenoid expander board explaining the jumper?
#28 3 years ago
Nowhere on the instructions did it say to cut the jumper for a specific game.
One simple small cut..wow
thanks again
$ 199.95
Other
$ 44.99
Pinball Shark
Shooter rods
$ 149.95
Allteksystems
$ 18.95
$ 45.00
Lighting
Yoppsicle
Lighting
$ 18.00
Third Coast Pinball
$ 22.95
$ 8.00
Third Coast Pinball
$ 119.95
Allteksystems
This page was printed from https://pinside.com/pinball/forum/topic/help-bally-fireball-classic-1-amp-playfield-fuse-blowing-on-power-up and we tried optimising it for printing. Some page elements may have been deliberately hidden.
